Fender Patch w/Braces
Old December 9th, 2015, 07:34 AM
anthonyP's Avatar
Does anyone happen to know of any manufacturer that makes lower 70-72 fender patches with the braces?
anthonyP is offline
Old December 9th, 2015, 09:51 AM
Unfortunately, none that I know of. The frustrating thing is that obviously the dies for the braces exist, since they come on the repro full fenders. No one wants to sell just the brace.
joe_padavano is offline
Old December 9th, 2015, 10:41 AM
Chevy budget Olds powered
coppercutlass's Avatar
even the patches suck i would advise against them. I made my own patches and made my own braces. Granted some fenders are worse than others but the body lines on the repops are rounder vs. crisp and cornered. I maintanined a 3/16 gap top to bottom on mine last time i used the patches it was very hard to keep it consistent. the only the patches are good for is for base work meaning you use the basid shape but will have to cut and shape as needed. I would only use the face and try to keep the edges in place so you dont loose the factory width as the patch stampings are very inconsistent.
coppercutlass is offline
Old December 9th, 2015, 10:58 AM
Nice work. I will say that there are now higher quality patches available for the 70-72 fenders. I bought both sides from Autobody Specialties at Carlisle last spring. They are about 50% thicker than the old ones and stamped from new dies that are MUCH closer to OEM shapes. I was pleasantly surprised. Of course, many vendors still sell the crappy ones, so you need to be careful when you buy them.
Old December 9th, 2015, 11:25 AM
ELY442's Avatar
Do they have quarter panel patches too?
ELY442 is offline
Old December 9th, 2015, 11:34 AM
Not that are any different than the others on the market. They DO have better floor pan patches, however. Again, about 50% thicker and much better definition on the stamping. I bought those as well.
Old December 9th, 2015, 06:51 PM
anthonyP's Avatar
Hello coppercutlass. Thank you very much for the information and photos. I will try to copy them so I can send them to my friend who is much more talented with metal working and welding then I am. Hopefully he can replicate the procedures, at least for the brackets. In the meanwhile, I will look into the Autobody Specialties patches and maybe have the brackets made for them. Thanks, Anthony
anthonyP is offline
Old December 9th, 2015, 07:06 PM
anthonyP's Avatar
Thank you Joe for the information. I am going to look into the Autobody Specialities and their fender patch panels. The fenders on the '70 442 are OEM and would hate to replace them, especially since the bottoms are only bad. It is hard to believe none of the sheet metal manufacturers have not seen the large market for fender patch panels with the braces, especially since most want to save the OEM fenders. I'm sure they rather sell their full fenders, but I tried that and wasted hundreds of dollars on aftermarket fenders that were not usable without hours upon hours of metal work to make them fit. Even after all that work, they would still be the incorrect gauge and without the crisp lines of an OEM fender.
anthonyP is offline
Old December 10th, 2015, 05:53 PM
Im sure if your buddy is handy with metal he can pull it off. Im just a bodyman with enough fab skills to make stuff. I have seen some serious patch work by amazingly talented fabricators where the patch work needed no filler work. Everything was but welded ground down and smoothed to shape.
Old December 11th, 2015, 03:28 PM
anthonyP's Avatar
If you were closer, I'd have you work on my car. Thanks again for the tips.
anthonyP is offline
Old December 13th, 2015, 03:09 PM
dads72's Avatar
I had the problem and ended up getting a NOS set of fenders out of AZ. I have a pair of the patch panels if you are interested...I either got them from OGPI or Fusick.
dads72 is offline
Old July 14th, 2016, 08:43 PM
anthonyP's Avatar
Update - While looking at the Buick Performance Club website, one of the pages noted reproduction lower fender braces. It seems the club president asked Sherman Auto Parts to make the replacement lower fender braces for their Buick fender patch panels.
Maybe some of the members who do body work can take a look at them to determine if these reproduction lower fender braces can be used with an Oldsmobile patch panel or fender.
anthonyP is offline
Old December 31st, 2021, 04:21 PM
Old Olds Fanatic
70 w-30's Avatar
What is Autobody Specialties website? I do a search and get body shops.
thanks,
Ben
70 w-30 is offline
Old December 31st, 2021, 04:24 PM
v8al's Avatar
They are in Middlefield, Connecticut.
v8al is offline
Old January 1st, 2022, 09:09 PM
cherokeepeople's Avatar
i got some rockers and patches for my 03 suburban from ABS those full rockers i swear weighed 40 lbs and fit like a glove.
cherokeepeople is offline
Old January 2nd, 2022, 09:06 AM
tkcutlass's Avatar
I'm lucky enough to be within 30 minutes of ABS. saves on shipping
tkcutlass is online now
virtualwsp
27
January 6th, 2015 08:38 PM
January 9th, 2012 04:32 PM
Tom442
May 31st, 2011 01:53 PM
bittersweet71
May 11th, 2011 10:43 AM
stevengerard
Body work
November 24th, 2010 11:54 AM
Quick Reply: Fender Patch w/Braces
