Bleeding/Filling Convertible Top Motor and Lines
Old March 26th, 2015, 02:38 PM
leroycjr's Avatar
Hi folks,
Have a convertible top question. We're putting things back together now looking good cant wait to show pics but I have a concern. When lowering the top I noticed that there is a lot of air going through the top lines and at some point on the way down I see no fluid going through the lines and of course the tops slooooooowly goes down. I stop trying to put it down so I don't burn out the motor.
My question is this. I had someone replace the hoses and so I know there is tons of air in the line. I've looked at the cryptic Fisher manual and does anyone have a easier way to FILL and PRIME the lines! OR do you have a craftier way of creating the hose that needs to be put into the motor. Looking for ideas as i want to do this next week.
Help would be greatful.
leroycjr is offline
Old March 26th, 2015, 03:02 PM
jcmoretti's Avatar
I remember reading that part of the manual when I broke a hydraulic line while working on the interior. I was confused.
Ultimately, I added fluid using some clear tubing and one of those colored ketchup/mustard squeeze bottles that my wife bought for parties. I didn't make the fancy plug the manual calls for.
I simply don't recall whether the air bubbles worked themselves out or not. But the top works, well except for the holes in it!
jcmoretti is offline
Old March 26th, 2015, 04:04 PM
m371961's Avatar
I disconnected the cylinders from the top frame, run them in and out and checked the fluid often as I did this. (they did not extend the same rate, one opened before the other) Used a squirt oil can to fill. Then as I saw less air, I hooked them back up and and did the same thing. Eventually I saw little air in the lines, topped it off and left it. I believe Hydro-E-lectric had instructions on line.
m371961 is offline
Old March 26th, 2015, 05:08 PM
So what is the recommended fluid? ATF?
Fun71 is offline
Old March 26th, 2015, 06:31 PM
QMaster's Avatar
Yes, ATF works. I had to replace a cylinder last year. I used the Hdro-Electric instructions and they worked fine.
QMaster is offline
Old March 27th, 2015, 06:00 AM
68442's Avatar
68 - up used ATF
67 - Down uses brake fluid
68442 is offline
Old March 27th, 2015, 03:13 PM
m371961's Avatar
If pump and cylinders are replaced ATF can be used. I would think if all is removed you could flush out the brake fluid and replace with ATF, but don't know for sure.
m371961 is offline
Old March 28th, 2015, 05:22 AM
68442's Avatar
Yes, that is correct.
68442 is offline
Old March 28th, 2015, 04:20 PM
tmaleck's Avatar
My new pump and hydraulics specifically said brake fluid would work but void lifetime warranty.
Tim
tmaleck is offline
Finn5033
October 10th, 2022 08:08 PM
kens69olds
Brakes/Hydraulic Systems
September 1st, 2014 07:15 PM
chasman414
January 7th, 2013 07:19 AM
tomdiet
September 5th, 2012 07:22 PM
silverriff
December 4th, 2008 01:51 PM
Quick Reply: Bleeding/Filling Convertible Top Motor and Lines
