'77 442 door latch issues
Old August 3rd, 2014, 06:09 AM
fknrc's Avatar
I'm hoping someone can help solve a door latch issue on my 77 442.
Both the driver and passenger doors do not fully latch when closed. The door hinges are tight and the doors don't sag. The strikers have only normal wear. And the rubber seals around the door seems to be in good shape. Can the door latches be repaired? Is there a source for replacement latches?
Any help is greatly appreciated.
Fred
fknrc is offline
Old August 3rd, 2014, 02:45 PM
jwsolds's Avatar
You say normal wear on the strikers but the most common problem is the striker. Are the grey plastic things still around the striker bolt? Missing all the time and that's why the doors don't latch tightly. They are actually called silencers and were recently still available thru GM parts in bag of 10 (enough to do five cars).
jwsolds is offline
Old August 3rd, 2014, 03:49 PM
fknrc's Avatar
I wasn't aware of the silencers missing from the striker bolts but it seems neither striker bolt has one. I will check with my local GM parts store to see if they are still available. If so, hopefully that will remove the play in the doors. In any case it will be cheaper to start with the silencers before laying out for new latches!
Thanks so much for your help.
Fred
fknrc is offline
Old August 3rd, 2014, 04:04 PM
jwsolds's Avatar
You have to remove the strikers to replace the silencers. Another alternative though more costly is to replace the whole striker as they are now being reproduced correctly I believe. Try Fusick or another Olds parts source. I'll try dig out my bag later tonight for the silencer part number for you.
jwsolds is offline
Old August 3rd, 2014, 04:22 PM
fknrc's Avatar
Thanks. I'll check out fusick and some others too.
fknrc is offline
Old August 3rd, 2014, 07:07 PM
texxas's Avatar
silencer, part number 9601752
Got mine in a bag of ten from a Chevy dealer. I'd think any GM dealer could get them or search the part number on the good ole interweb. You need these for your doors to latch properly.
texxas is offline
Old August 5th, 2014, 11:05 AM
fknrc's Avatar
thanks. I'll check with my local chevy dealer.
fknrc is offline
Old August 11th, 2014, 05:10 PM
fknrc's Avatar
I want to thank both JWSOLDS and TEXXAS for your help on my door latch issues. I contacted my Chevy Dealer with the part number provided.
The silencers arrived today and when installed corrected my door closure problems. Now my door close like new! So thanks to JWSOLDS for alerting me to the silencers and to TEXXAS for sharing the part number. Even the Chevy guys were surprised the part was still available!
Fred
fknrc is offline
Old August 18th, 2014, 07:30 PM
texxas's Avatar
Fred
FRed, You're welcome, I'm glad this fixed your door problems. As far as those "Chevy Guys" they're easily impressed.
Got any pictures of your 77 442?
texxas is offline
Old August 20th, 2014, 06:05 AM
fknrc's Avatar
Here are pic's of my current projects. I am currently restoring the white one which was originally purchased as a parts car for the brown car. But it was too good to part out.
fknrc is offline
Old August 20th, 2014, 10:32 AM
texxas's Avatar
Ah yes, I'm well familiar with the parts car that ends up being too good too use for parts. I ended up with two 79 Olds 403 powered Pontiac Trans Ams this way. The parts car was nicer than the one I was looking to fix up, now I have two. Nice cars, I'm glad you're saving both.
texxas is offline
LJHoney
July 7th, 2014 10:24 AM
Danielle's 71
September 21st, 2009 04:06 PM
squirtacious
August 27th, 2009 12:29 PM
a64olz
May 4th, 2009 07:26 PM
pippy
November 7th, 2007 07:00 AM
Quick Reply: '77 442 door latch issues
