Door hinge roller
Old January 29th, 2012, 11:28 AM
69postman's Avatar
Door hinge roller
How does the pin come off for the detent roller? The roller is off already because it was worn out. Now with new bushing in roller, it does not go over head of pin. Does the pin come out somehow? My manuals don't show hinges. Thanks Brian
69postman is offline
Old January 29th, 2012, 04:26 PM
Lady72nRob71's Avatar
Not sure how close the '69 hinge is to the 72, but if they look alike, then the procedure would be the same.
You may have to grind off the retaining tabs off the bottom of the pin. A dremel tool works best.
This might help you...
https://classicoldsmobile.com/forums...tml#post155187
Lady72nRob71 is offline
Old January 29th, 2012, 05:07 PM
69postman's Avatar
Ok thanks that helps!!
atkinsom
November 9th, 2012 09:53 AM
Redog
August 14th, 2008 06:56 PM
bear71
October 22nd, 2007 02:00 PM
dyscookn
February 16th, 2007 12:24 PM
polcatt
October 8th, 2006 07:03 PM
Quick Reply: Door hinge roller
