| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Body work All body work discussion including vinyl tops |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
72 Cutlass Covertible window issues
Guys, I had a new top put on over the weekend. I am having a HORRIBLE time trying to adjust the rear windows.I have the Body/Chassis manuals, but they are too vague. Can someone please walk me through what I should loosen to adjust the rear windows. I am pulling my hair out. It wont quite meet the top in the corner and then, I can't get it to adjust properly to the front glass. The front door glass is flush at the front post and the roof. I just can't figure out how to adjust the rear windows properly.
I really need some detailed help. Thanks again |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Certified Fanatic
The only thing I can suggest is to let your mind float when you are sitting on the car floor looking at the two windows and try to imagine what the adjusters do
it's an abstract thing and very hard to describe what to do first...and then there must be a step by step somewhere which I have not found yet, but my windows work after doing at least four '68 Cutlii patience Grasshopper...![]() ![]()
__________________
![]() '57 S88 HC et al; '68 442 M20; '68 442 M21; '68 W30; '68 Vista et al; '80 -'84 Regency et al; '96,'98.'99 Aurora..Ignition ON ![]()
#3 (permalink) |
Cruisin' the Vistas
Did the windows fit okay before the top was put on? It could be the top that needs adjusting if so.
#4 (permalink) |
There are two upper stops with adjustment bolts. See in this picture: http://www.flickr.com/photos/robsalb...7602930020786/
It sounds as if the rear stop needs to be raised some to align with the front glass. (The recessed one at the upper left of the picture.) The one in the middle under the black sealant blob might need tweaking, too - it controls the total up travel. As mentioned above, a good studying with a mechanical mind helps most. The body manual is not as helpful as is should be...
__________________
-Rob Young 1972 Cutlass Supreme Convertible (442 clone) -"Lady" (My mistress...) http://www.flickr.com/photos/robsalbum/sets/ 1986 Cutlass Supreme Coupe - "Pristine" 1978 Ford (Old Faithful) a.k.a. "the Tramp" 1997 Cadillac STS (for sale - too many cars!) 1999 Harley Davidson Sportster - "the Freedom Machine" Last edited by Lady72nRob71; May 6th, 2009 at 06:07 AM.. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 69-98 covertible cleanup | wolfman98 | Major Builds & Projects | 1 | February 20th, 2009 11:43 AM |
| W30 4Speed Covertible Collection | z11375ss | 442 | 18 | October 18th, 2008 08:35 PM |
| 65 cutlass 330 issues | olds382 | Small Blocks | 1 | August 14th, 2008 11:08 AM |
| 1970 covertible frame | htlong | Cutlass | 2 | August 13th, 2007 04:54 PM |
| '69 cutlass 350th trans issues,,, | macarthur | Transmission | 0 | July 25th, 2006 01:46 PM |
