rust inside door and trunk lid
Old August 22nd, 2016, 08:21 PM
Photoshop God
DewChugr's Avatar
How do you deal with light rust at the bottom of the door on the inside and inside the trunk lid, between the two layers?
DewChugr is offline
Old August 22nd, 2016, 10:06 PM
Most people just ignore it, since they garage their cars and that rust will never get any worse.
You could spray it with oil if you want, or try to de-rust and paint it, but that would require complete disassembly of the doors to be really effective.
MDchanic is offline
Old August 23rd, 2016, 03:04 AM
chopolds's Avatar
If the parts are still on the car, use some clay or putty, and block up the drain holes. Then pour in some metal prep. like Dupont 5717S, or Picklex. Let it sit for a while (10-15 min.) then remove the putty, & drain it out. Most preps will leave an iron phosphate film , that is a bit resistant to rusting, but for better insurance, coat it with a rust preventative, like Master Series, or POR-15. Check to see if you have to neutralize, or flush the metal prep first, though. Should be in the instructions for the preventative.
chopolds is offline
Old August 23rd, 2016, 08:49 AM
I'll just add to the previous post that often the rust is caused by debris that settles into that joint and retains moisture. If possible, you should try to remove any dirt, leaves, etc that are in there first, and be sure to clear the drain holes before starting. Once you've done that, the Picklex process described above is a good one.
joe_padavano is offline
ferndaleflyer
May 14th, 2014 05:45 AM
dnmfranco
November 9th, 2013 01:44 PM
1k442
August 30th, 2013 10:20 PM
Jay D
May 20th, 2012 11:03 AM
oldspackrat
September 18th, 2011 07:31 PM
Quick Reply: rust inside door and trunk lid
