442 W30 stipe layout for 1971 olds? (406787)
Old June 8th, 2011, 11:12 AM
MLK-442's Avatar
Hello all,
Does anyone have the W30 pinstripe layout prints for a 1971 W30 442? I have the assembly manual but that only references the actual layout drawing, 406787, and provides some dimensions but not enough to lay out correctly. I do not want to use the stencils, I intend to use stencil tape and layout on the car directly then paint.
BAP use to sell the blueprint (406787) but no longer carries it, not sure why.
Thanks in advance,
MLK-442
Last edited by MLK-442; June 8th, 2011 at 07:13 PM. Reason: incorrect layout number
MLK-442 is offline
Old June 8th, 2011, 06:26 PM
"Car"mudgeon
GAOldsman's Avatar
Supercars Unlimited
70-72 W-30 & 70 W-31 Paint Stripe Stencil Kit
The easiest and most precise method of assuring correct stripe position, size
and configuration. This kit allows the painting of perfect stripes by means
of a high quality stencil. Accurately duplicates the factory stripes. Complete kit includes hood, trunk and sides. Compatible with all types of paint. Detailed instructions included. Specify hardtop or conv..PART NUMBER 01-284..PRICE: $199.95
http://www.supercarsunlimited.com/It...m?CategoryID=9
Scot
GAOldsman is offline
Old June 8th, 2011, 07:11 PM
MLK-442's Avatar
Thanks Scot but you may have missed my point in the post. I do not want a pre-made stencil. I am looking for the layout information (oldsmobile print #406787), dimensions, radius, distance from edge of steel, etc. I will lay out on car myself with stencil tape.
MLK-442
MLK-442 is offline
Old June 8th, 2011, 07:32 PM
"Car"mudgeon
GAOldsman's Avatar
Gotcha, I've checked and this is the best one I could scan. I think it's going to be challenging but you should be able to pull it off.
Old June 8th, 2011, 08:02 PM
"Car"mudgeon
GAOldsman's Avatar
This may help as well....
http://www.realoldspower.com/phpBB2/...tripe&start=15
Old June 8th, 2011, 08:16 PM
70Post's Avatar
Someone should have the hand-drawn page that's floating around out there. It's accurate in terms of measurements and shows radiuses, etc.
Anyone have it??....it was drawn up by Bob Gerometta back in the late '70's I believe. I have one but no scanner.....I can verify it and/or compare whatever gets posted to mine if you want.
I swear I've seen the page posted here or on ROP.com.
70Post is online now
Old June 9th, 2011, 09:31 AM
"Car"mudgeon
GAOldsman's Avatar
Here's Bob's email address if you want to shoot him an email... bob.gerometta@wildaboutcars.com
I looked over at the wac.com site but to no avail.
Scot
Old June 9th, 2011, 09:37 AM
stevengerard's Avatar
I have one somewhere, I'll look for it tonight
stevengerard is offline
Old June 9th, 2011, 09:42 AM
Tucsonbob's Avatar
Is there any difference between the '71 W30 striping and that of the '70 W30?
Tucsonbob is offline
Old June 9th, 2011, 11:27 AM
70Post's Avatar
Bob - No difference...they are the same striping
Old June 9th, 2011, 02:00 PM
Tucsonbob's Avatar
Thanks Patton. I am interested in this as well. Car is being soda blasted next week.
Old June 9th, 2011, 02:11 PM
"Car"mudgeon
GAOldsman's Avatar
Here is an email reply from Bob Gerometta to MLK-442 and myself...
"If you join wild about cars www.wildaboutcars.com the blueprints are on line at Factory Publications/Oldsmobile/Factory Technical Supplements/ 1970. If when you register, you select "Oldsmobile" as your Brand Affiliation, then when you hit your "Dashboard" (your home page), you will see an Olds logo in the upper left corner - click on "Factory Publications", then select "Factory Technical Supplements", and then the year 1970. You will see the drawings - they are half scale - but they are the original engineering blueprints. You can download the files (they are PDFs) and take it to a printer like Kinko's and have them print it out for you or you can reference them on-line - your call. Good luck. Once you have signed up - you will have a whole new world opened up to you of Oldsmobile information - tell your friends. Bob "
It is a great site with a plethora of info and clubs within the wild about cars website. I encourage everyone to check it out and it's free.
Scot
Old June 10th, 2011, 04:19 AM
MLK-442's Avatar
GAOldsman thank you so much for providing Bob's email. This site is fantastic! Lot's of great information for us.
Bob, thank you for running this site. Excellent!
BTW, need to definitely donate to this site......
Have a great weekend everyone, I know I will. Gonna be painting away!
MLK-442
MLK-442 is offline
Old June 10th, 2011, 09:06 AM
"Car"mudgeon
GAOldsman's Avatar
No problem MLK-442, it is a very informative site and I hope everyone takes advantage of it and joins as well.
Scot
hurst68olds
September 9th, 2014 09:45 PM
Jimi2much
January 8th, 2014 04:34 PM
jbevins
October 15th, 2013 05:26 PM
Kyle's 77 Cutlass
February 15th, 2012 06:02 AM
54olds
August 7th, 2008 12:20 AM
Quick Reply: 442 W30 stipe layout for 1971 olds? (406787)
