1969 cutlass lug nut stud problem...
If you do get it out without pulling the axle, install the new stud and again use a stack of washers or a section of pipe and pull the new stud into place with the lug nut. Otherwise, just use the press to put the new one in also. Whatever you do, do not just hammer on the axle flange. That's a good way to bend it.
