Oil drain back
Old February 7th, 2015, 10:26 AM
cwb442's Avatar
Oil drain back
Is it necessary to open up the oil drain back holes in the heads. I have restrictors in the cam. Just got a set of c heads back from being freshened up and noticed this was not done when comparing to a set of j heads that were previously on engine.
cwb442 is offline
Old February 7th, 2015, 11:41 AM
No, not generally.
What are you using it for? What sustained RPM are you planning on running?
MDchanic is offline
Old February 7th, 2015, 05:04 PM
cwb442's Avatar
70%street/30%strip. Max rpm 5500
cwb442 is offline
Old February 7th, 2015, 07:52 PM
I'll let the drag racing guys answer for the strip, but I don't think you have anything to worry about.
MDchanic is offline
Old February 8th, 2015, 11:19 AM
D. Yaros's Avatar
I guess I do not understand. What advantages are there to not opening up the drains?
D. Yaros is offline
Old February 8th, 2015, 05:09 PM
For sustained high-RPM use, such as running at 5,000 RPM for long periods while racing, it is possible to pump all of the oil out of the pan, but have it not be able to drain back fast enough.
Not a problem generally encountered in any normal kind of use.
MDchanic is offline
Old February 8th, 2015, 05:24 PM
steverw's Avatar
It certainly couldnt hurt anything it the heads are off the car. I dont think you can open them up much, but i dont know how much is possible. There is a danger of getting into the water jacket. You can just smooth them some and the floor around them. Maybe someone else knows how much they can be opened.
steverw is offline
Old February 8th, 2015, 06:39 PM
cwb442's Avatar
I did not request it to be done. Just wondering if it's a make or break mod with my motor. Valves/valve springs are installed ready to be put back on. Dump is scheduled for next Thursday. So all I'm asking is should I bring the heads back have them disassembled again to open up drain holes or will I be ok.
cwb442 is offline
Old February 8th, 2015, 06:49 PM
cwb442's Avatar
Correction dyno time is scheduled for next Thursday. Looking at how the j heads were opened up. To me it looks like it was mounted at an angle on a drill press and opened up to about a 5/8 hole which maybe a 1/2" deep which opened up drain hole at an angle.
cwb442 is offline
Old February 9th, 2015, 01:39 PM
D. Yaros's Avatar
OK, thanks! I think I understand now. So the op was talking about "enlarging" the drain holes, as opposed to unplugging them. That they would be plugged made no sense to me and is what had me confused.
D. Yaros is offline
rootney
November 20th, 2014 12:39 AM
66-3X2 442
October 16th, 2014 02:57 PM
brandon 455
July 14th, 2013 04:16 PM
geckonz08
November 25th, 2009 09:01 AM
Quick Reply: Oil drain back
