Intake Manifold can I use '68 400 4bbl intake on my '67 E block?
Old December 18th, 2014, 07:35 AM
shamusj's Avatar
My '67 manifold has a few cracks in it….my '68 looks clean.
Just want to make sure everything will mate up- they look to be the same minus the choke area (depth of hole ).
THanks
shamusj is offline
Old December 18th, 2014, 07:40 AM
Aside from the choke coil, as you note, they should be functionally the same.
MDchanic is offline
Old December 18th, 2014, 07:59 AM
Old School Olds
tru-blue 442's Avatar
You will also be able to use a thermal ported vacuum switch with the 68
if you wish. It will have the provision for it.
tru-blue 442 is offline
Old December 18th, 2014, 08:31 AM
Oldsmaniac's Avatar
Or have a port for an aftermarket temp gauge....
Oldsmaniac is offline
Old December 18th, 2014, 08:44 AM
Old School Olds
This is true, have one of those available too!
Old December 18th, 2014, 09:28 AM
Octania's Avatar
Any such intake will do.
Maybe move to electric choke and forget the remote coil?
If your intake is '662 J casting I could maybe trade a later 70-72 casting for it. I make the J into '69 H/O J-405233.... you can use ANY intake, I can only use J-398662.
Octania is offline
PAULIE
January 21st, 2023 03:23 PM
240 Gordy
January 28th, 2014 03:37 PM
cts-v
August 30th, 2013 09:22 AM
Gaz Hog
April 22nd, 2010 07:49 AM
Gaz Hog
March 31st, 2010 07:21 PM
Quick Reply: Intake Manifold can I use '68 400 4bbl intake on my '67 E block?
