455 Valve Springs
Old November 26th, 2014, 05:53 PM
Rocketbrian's Avatar
455 Valve Springs
With a 71 G head with rotators and therefore deep spring pockets are there special longer springs for this application or do you have to shim each spring?
Rocketbrian is offline
Old November 26th, 2014, 06:28 PM
Octania's Avatar
Use Rotators?
Octania is offline
Old November 26th, 2014, 07:16 PM
cutlassefi's Avatar
Shallow spring pockets use a spring height of approx 1.670, deep pockets are around 1.800. Let me know if I can help.
cutlassefi is online now
Old November 27th, 2014, 12:21 PM
I thought this would be a simple yes or no answer, with a little info on where to get them if it was an unusual item. The 442 in 71 has rotators on both intake and exhaust valves and therefore all deep seats, along with dampers and large intake valves. Surely someone has redone G heads.
Happy Thanksgiving to our southern neighbors.
Old November 27th, 2014, 12:56 PM
67 Cutlass Freak's Avatar
Exactly what do you need? I have a bunch of parts laying around here.
67 Cutlass Freak is offline
Old November 27th, 2014, 01:40 PM
I just want to know when ordering valve springs are there different ones for shallow vs. deep seat heads? Some G heads have all deep or a combo of shallow and deep seats. I'm concerned about valve spring height. I'm thinking if they are sized for shallow seats then shims would be necessary under the springs in deep seat heads. I just want confirmation one way or the other. Thanks.
Old November 27th, 2014, 01:47 PM
As a follow up perhaps if you keep with the rotators no shims would be necessary as the rotater obviously takes up the difference. I guess my question in hindsight is only applicable if one chooses to omit the rotators and go with retainers in a deep seat head. What's the feeling on omitting vs. keeping the rotators?
Old November 29th, 2014, 05:43 AM
GOSFAST's Avatar
Recently finished some "G" heads (409-100) with a final installed spring hgt of 1.900" with the factory length valves.
Spring pressure was 140# @ 1.900" with 340# open for a retro-hyd roller build. Made the 1.900" hgt easily.
This was all for a '71 "442", 455" 100% stock-appearing unit, roller rockers, stock valve covers.
(Add) There were no "rotators" used in the end product.
Thanks, Gary in N.Y.
P.S. Setup used all Comp components (I believe, have no numbers available here), dual springs, l/w tool-steel retainers, and 10* locks.
GOSFAST is offline
Old November 29th, 2014, 03:10 PM
Thanks for the info and reply.
bigjaythe1st
Suspension & Handling
May 8th, 2012 05:45 PM
1acesmith
August 11th, 2011 11:03 AM
jensenracing77
March 13th, 2010 12:41 PM
rcdynamic88
February 18th, 2010 07:46 AM
Redog
December 29th, 2008 06:32 PM
Quick Reply: 455 Valve Springs
