| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Carb. interchange
I have a "new" rebuilt 4 barrel Rochester Qjet correct for a 1976 350 Cutlass. My 1970 Olds 98 455 needs a carb. Can I use this on my 98? I've noticed the Vac. break assembly is different. Thanks.
Tom
__________________
1976 Cutlass S Centennial 1970 Ninety Eight LS |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Super Moderator
You can use it but it won't be jetted properly. On the other hand, it's a testament to the Qjet that the engine will probably run acceptably.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#3 (permalink) |
OK. Thanks Joe. I'll get the correct carb. Just trying to save a few bucks but if it won't run the way it should then I'll wait.
Tom
__________________
#4 (permalink) |
Super Moderator
It will run OK for most uses (I've done this). You can change the metering rods later if needed.
__________________
#5 (permalink) |
Landyacht Club President
Metering rods cost less than $5.00 new from Summit.
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper! Cameron Frye Ferris Bueller's Day Off 1986 |
#6 (permalink) |
Just the facts...
other major differences include:
primary jets power piston spring secondary metering rods fast idle cam choke stat and coil opening rate air bleeds and passage restrictions accelerator pump squirt volume air valve spring wrap and most of the set up adjustments yes it may "work", but likely, not very well compared to the carb. that should be on top of that '70 455. bill
__________________
'67 CUTLASS 4-DR. W/425 & S.P. THM400 (NAMED "ERNIE") '83 H/O #1339(STILL IN PIECES) '85 PONTIAC FIERO SE V-6 4-SPD. BOUGHT NEW '92 CHEBBY DIS-ASTRO (GAS PIG) '97 GYRO METRO $HYTBOX (41.42 MPG)
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Flywheel Interchange | millwrightrice | Small Blocks | 1 | July 25th, 2007 08:59 AM |
| Interchange? | Jetstar88 | Other Oldsmobiles | 1 | June 8th, 2007 08:37 AM |
| Head interchange | Chumley | Small Blocks | 1 | April 27th, 2007 10:28 PM |
| suspension interchange | mattnsac | Chassis/Body/Frame | 1 | March 26th, 2007 07:15 PM |
| Transmission interchange | Harrold | Transmission | 3 | February 19th, 2007 04:04 PM |
