ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old January 9th, 2003, 03:06 PM   #1 (permalink)
SUGRUE
Junior Member
Post
I HAVE A 66 425 FROM A TORO AND WANT TO INSTALL IT IN A 79 TRANS AM TO GIVE ITA LITLE PUSH, ANY THING YOU COULD TELL ME WOULD BE HELPFULL, THANKS
SUGRUE is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old February 16th, 2007, 09:08 PM   #2 (permalink)
rick pilgrim
Junior Member
Smile Olds 425/455 to Trans Am
I can tell you from experience a few things. If your T/A came with a 403 or 307 It's pretty much a bolt in. If not you will need to do some parts hunting. You need to find Olds motor mounts from either one of the Nova clones or F-body cars of that era. Exhaust is best with a set of W-30 manifolds, or find custom headers. Toronado manifolds while being dual exhaust wont allow pipe hookups in the right place. Find either a RWD car 4qt oil pan or aftermarket pan for Cutlas, The Toro pan will fit but in our Camaro it was way to close to the ground. A BPOC pattern Tranny is needed, Unless your crankshaft is machined for a manual trans(very few are, and have not seen one in a Toronado) you will need a automatic. We tried a Turbo 350 and untill we found traction it worked. I ended up with a Turbo 400 automatic from a '70 Delta 88 with a shift kit. You can get a built (performance upgrade) TH350 but make sure it has a improved sprag and it will hold up under 550ftlbs of torque. We had a radiator shop make us a radiator with double(4 row) core, Summit Racing sells some that fit. Alternator/ps/fan we went with aftermarket parts. Stick with the Toronado intake manifold, unless you want a hole in the hood. Edelbrock performer with 2"spacer, Q-jet and 14x3 air cleaner means 4" cowl induction hood. When all done you will have a big smile on your face.
Lastly, A 425 is a 10.25 compression leaded fuel engine. If you run it on pump gas, 92RON, 104+ octane boost X2, and a lead replacement addative is a must. And set your redline at 5200-5400 with a stock oiling system. Mondello Olds has what you need to inprove the oiling system.
Hope this helps,
Rick
rick pilgrim is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
'68olds ninety-eight convertible rocket9r8 Ninety-Eight 4 January 30th, 2008 05:53 AM
exterior visor for a 1953 Olds 98 tarps3 Chassis/Body/Frame 1 February 16th, 2007 07:53 AM
Engine Stand Question Green Machine Eighty-Eight 1 May 18th, 2006 01:28 PM
1988 Cutlass Ciera battery replacement bermuda Cutlass 0 May 18th, 2006 12:38 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
