Which vacuum ports on my Quadrajet?
Old June 7th, 2014, 07:46 PM
Tom442's Avatar
How do I find out what ports to use for my vacuum advance, transmission modulator(It is connected correctly I hope) and the vacuum ports on the dual snorkel air cleaner on my 7041251 carb I had built by Sparky. There is also a brass nipple on the top rear of my performer for direct manifold vacuum. In the pictures I have capped the three unused tubes on the carb and the one on the intake so you can see them better. This is on my 68 442
Any input would be greatly appreciated.
Tom
68 442
70 F85
Tom442 is offline
Old June 7th, 2014, 09:55 PM
This should help with some of you questions:
Distributor vacuum advance typically connects to the capped port above the idle mixture screw on the driver side of the carb.
Auto-thermic valve on the air cleaner should connect to the manifold vacuum port on the rear of the intake.
Fun71 is offline
Old June 8th, 2014, 03:48 AM
Just curious - If Sparky just rebuilt it, why not just ask him what to connect where?
Kenneth just laid it out, though.
MDchanic is offline
Old June 9th, 2014, 02:29 PM
Tom442's Avatar
Frankly, I was embarrassed to ask Sparky cause it has taken me so long to get my 442 running again. I have sent him a note and I'll see what he tells me. Thanks to you guys, Eric and Kenneth for your input.
Tom
68 442 it now starts
70 F85
Tom442 is offline
Old June 9th, 2014, 04:54 PM
allyolds68's Avatar
It's all in the assembly manual
allyolds68 is offline
stlbluesbrother
October 23rd, 2012 09:50 PM
rmoths
September 3rd, 2012 04:40 PM
rcdynamic88
October 19th, 2010 06:05 AM
DAN76
June 24th, 2009 01:43 AM
blonzz
September 27th, 2004 10:54 AM
Quick Reply: Which vacuum ports on my Quadrajet?
