Go Back   ClassicOldsmobile.com > Repair & Restoration > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-02-2008, 04:36 PM   #1 (permalink)
70oldsW30
Member
70 455 bottom end assembly
There should never be a reason to get the main bearing caps out of order since the number/order is cast into the cap iteself. Numbers are facing towards the front but also the recess for the bearing tangs on the caps go together with the similar tangs cast into the block.
Similarly, connecting rod caps can always be properly assembled onto the rod because the recess for the bearing tangs on the caps go together with those cast into the rods. Rods can always be properly oriented in the cylinder be making sure that the little oil spithole that is cast into the rod where it mates with the rod cap points inside, or towards, the crankshaft.
There is only a need to number the rod/piston assembly if the pistons will not be replaced and the intent is to reassemble the motor with the same rods and pistons.
Please delete the thread if any portion is incorrect.
Goodnight.
70oldsW30 is offline   Reply With Quote
Sponsored Links
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
ASSEMBLY INSTRUCTIONS 71cuttyS Chassis/Body/Frame 0 02-13-2008 10:05 AM
1970 olds 98 455 rear end posi troy1 Ninety-Eight 4 02-12-2008 01:49 PM
No bottom end torque magnusdog Small Blocks 5 08-01-2007 07:48 PM
4 row radiator mounting top and bottom supports muddy 442 12 06-10-2006 04:24 AM
371 Starter ring/bottom cover Lobo Parts Wanted 1 06-29-2004 09:05 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
