Go Back   ClassicOldsmobile.com > Repair & Restoration > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 04-06-2008, 06:54 AM   #1 (permalink)
colinanj
Junior Member
EASY QUESTION - A LITTLE HELP
Hi All,
I'm not an Olds person, and just picked up my first Olds, so can someone give me a little help:
Just picked up a 1970 Olds 442 which we know is an authentic 442, has correct exhaust manifolds with correct #s, original ram air hood. We ID the block as a 70 455.
I was told in order to verify the vin number as a matching numbers block, the power steering pump must be removed in order to access the #.
Is there any other way to verify this is a matching #s car and should a portion of that # match a portion of the VIN?
Thanks!
colinanj is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 04-06-2008, 08:22 AM   #2 (permalink)
don71
feed the pig
This might help, there is link to a picture in this post.
http://classicoldsmobile.com/forums/...what-year.html
__________________
1971 Cutlass S 455/th400 3.23 rear---new interior allmost done.
don71 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Old spot welds, Is there an easy way to find them? Thuffner3 Chassis/Body/Frame 4 12-11-2007 07:38 PM
jetaway to turbo hyd 350 easy or hard? big-al-D-88 Eighty-Eight 30 12-02-2007 01:09 AM
Easy ? RE: Front Seal kcompton Big Blocks 3 11-16-2006 04:42 AM
you would think rewiring a car would be easy... 1BAD68"S" Electrical 3 11-09-2006 04:30 AM
how easy is it? RussTad Cutlass 3 09-19-2006 02:16 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
