Go Back   ClassicOldsmobile.com > Repair & Restoration > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 03-31-2008, 11:26 AM   #1 (permalink)
Eddie Hansen
Member
looking for input...
Hey fellas just looking for some ideas right now,
I have a 69 cutlass convertible, 4 speed, 3.08 posi
now I did get myself a 69 455, it has c heads, but with the smaller valves, I beleive it must have been the 2v motor? when I picked up the motor the heads were off, and looking at the bores there is absolutely no lip etc, and generally everything looks fine.
Now for the ideas, I want to put the 455 in the cutlass, I know i will need the crank drilled for the 4 speed, but as this is going to be purely a street engine, and not even much stop light racing, I was wondering how much compression is good on todays gas? I have power brakes. I am NOT looking for every horsepower out of this thing, but would like some ideas if
1. the bores are as good as they look, and it doesn't need boring, should i just use the stock pistons? with a new set of rings, do the bearings, get a high volume pump etc, what is that 9 to 1 compression? or is it worth the cost to get a complete kit from paw or something? have it bored etc etc what kind of timing chain?
2. I will have a valve job done, is it really worth it to put the 2.07 valves in? or if everything is as good as it looks just have a good valve job done etc etc.
3. Funny enough I would probably go with roller tipped rockers just for the adjustability, which ones are recommended? what cam?
4. I have a stock 4 bbl manifold, and I did get a holley rebuilt quadra jet that was correct for the application/year, should I toss this and get a performer manifold? or something else?
5. what is a good pressure plate/ disc for this set up, I think I put a hayes pressure plate ( stock type) and disc, last time, but that was for a 350?
6. Can I use the 350 flywheel?
7. Do I need to change the motor mount plates on the chasis for the 455? or can I just ues the 350 mounts?
8. I have the 69 442 exhaust manifolds ( I believe they are the w & Z) what size exhaust would be best and any recommendations for a stock sounding rumble ( not really interested in the 3 inch pipes and flomaster sound...been there done that, got the hearing aid...LOL..)
9 any other thoughts..... trying to resurrect my restomod, basically looking for decent performance on today's pump gas, but not looking for a drag car...
thanks in advance fellas...
Eddie Hansen is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
input on wheel selection.... 72Cutlass Cutlass 4 02-04-2008 02:57 PM
should i buy this 455 f block? i need input plz shaks 442 clone Big Blocks 20 12-19-2007 01:46 PM
I need your input on this 98! dar83501 Ninety-Eight 23 12-10-2007 03:24 PM
Need input on color choice for my 72 Olds. tex70 Cutlass 11 04-30-2007 08:46 AM
Need some input cwd56 Cutlass 2 10-22-2006 10:54 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
