Go Back   ClassicOldsmobile.com > Repair & Restoration > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 11-12-2007, 10:28 PM   #1 (permalink)
canucklehead
Junior Member
425 oiling
Greetings Olds Fans.I was told that I will need to upgrade the oiling system if I go high performance with my 425.What is needed?Do I need restrictors?
I am thinking 6 or 7 quart oil pan high flow pump and windage tray.Will this be enough?
canucklehead is offline   Reply With Quote
Old 11-13-2007, 12:09 AM   #2 (permalink)
88 coupe
Junior Member
Main bearing clearances = .003”
Rod journal clearance = .002”
Rod side clearances = .018”
Restrict the oil flow through the pushrods.
Drill a ⅛” hole in each cam bearing, 180° from the existing one, and install them upside down.
High volume pump.
7 or 8 quart pan with 5 or 6 quarts of 10w50, with a Fram HP2 filter.
Forget the windage tray.
Norm
__________________
Quote:
Originally Posted by Texascarnut View Post
Well Norm, if you knew much about '62 Oldsmobiles you would know ........
88 coupe is offline   Reply With Quote
Old 11-13-2007, 09:46 AM   #3 (permalink)
joe_padavano
Quote:
Originally Posted by 88 coupe View Post
...Restrict the oil flow through the pushrods....
Norm,
Years ago I remember reading about a trick of stuffing a pipe cleaner in the pushrod to restrict oil flow. Any thoughts on methods you're familiar with?
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old 11-13-2007, 06:07 PM   #4 (permalink)
442Harv
Member
I would not put pipe cleaners in the push rods, just would not want to take a chance? Probably the worst the could happen would be a pluged up rocker arm? The one post about redrilling the cam bearings, makes sence. The machine shop I use also says, he has off set the oil hole on the cam bearings. I have the restricked push rods in my 70 W30.
442Harv is offline   Reply With Quote
Old 11-13-2007, 06:48 PM   #5 (permalink)
88 coupe
Junior Member
Quote:
Originally Posted by joe_padavano View Post
........ Any thoughts on methods you're familiar with?
Yep. You might be remembering this thread.
From post #21.
........ Lifter bore restrictors have been used with solids for about as long. Pipe cleaners were commonly used to restrict pushrods until Mondello started selling his “store bought” versions.
For the $112 difference, I’ve always used the cheaper method and have had no problems .........
Quote:
Originally Posted by 442Harv View Post
I would not put pipe cleaners in the push rods ........
Your choice.
........ the worst the could happen would be a plugged up rocker arm?
Not possible.
Norm
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
425 Piston canucklehead ClassicOldsmobile General Discussion 1 11-06-2007 05:09 PM
Complete '66 425 for $99??? 425cid_260Z Big Blocks 2 07-25-2007 05:05 AM
'65 425 Outlaw Minis Big Blocks 3 07-20-2006 09:30 PM
425...improving oiling tndonor Big Blocks 2 07-10-2006 07:28 PM
425 Dave Transmission 1 04-06-2004 05:16 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
