pictures of 1969 442 400 motor
I'm looking for some pictures of a 1969 442 W-30 400 motor with air cleaner on and with air cleaner off. I replaced the 350 auto in my car with the original 4 speed and while doing it I am running the pos. battery cable where it belongs next to the valve cover. I want to see the proper way the to run the cable with the clips and wire ties,other wires and the vacum lines for the air cleaner. I also installed power brakes and would like to see the correct way the vacum hose braket is attached to the valve cover and should I run the bat. cable over or under it. manual pics. are not detailed enough. thanks for any help and pictures
Why rely on a pic that may not be accurate?
It is illustrated in the 1969 Product Information Manual at Wild About Cars. Can't say if it is detailed enough for you, but how do you know you can trust a pic?
Wild About Cars. http://wildaboutcars.com
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
atkinsom
August 24th, 2012 03:06 PM
