Holley 3 barrel
Old July 2nd, 2011, 05:39 AM
Tony
archeryshooter's Avatar
Holley 3 barrel
anybody here know if a holley 3 barrel with the part number 3916-1s is a 3150 or a 3160?
archeryshooter is offline
Old July 2nd, 2011, 06:20 AM
Never heard of one.
When did these creatures walk the earth?
MDchanic is online now
Old July 2nd, 2011, 06:57 AM
TripDeuces's Avatar
I believe the carb was introduced in the late 60s or early 70s. It was rated at 950cfm and had one big oval throttle blade in the secondary side with the standard two holes up front. I think I remember AMC using them. Occasionally you will see some intake manifolds with a little notch cut into the rear wall separating the right and left halves of the manifold. Many mistakenly think this is to help the dual plane act more like a single plane but it's not. It's there so the throttle blade doesn't hang on the wall separating the two halves at WOT. It's designed for a big block (the AMC thing doesn't make sense, lol) with that kind of air flow. It was more a NASCAR design than anything else. I haven't heard anything bad about them and they use most standard Holley parts, at least up front.
If you're going to use it on a dual plane intake just be sure to notch that wall or it can't open all the way.
TripDeuces is offline
Old July 2nd, 2011, 07:27 AM
stan 65 cutlass's Avatar
also used on dana camaros, i read once
stan 65 cutlass is online now
Old July 2nd, 2011, 09:05 AM
Oldsdruid
rocketraider's Avatar
I couldn't tell you as I haven't seen one in 30+ years. A buddy ran a Camaro drag car with one for a couple seasons- actually set a track record with the thing.
I remember a local Chevy punk bought one and set it on a dual plane manifold without relieving the divider and then talked stone schit about it because it ran worse than the QuadraJet he replaced with it (and didn't have common sense enough to realize why). He sold it (cheap!) to a Mopar guy who set it on a Duster 360 with a Torker and it ran like a raped ape. As TD has mentioned, borderline too much carb for that engine.
rocketraider is online now
Old July 2nd, 2011, 10:30 PM
toro68's Avatar
I read about that subject as well. A rare item for sure.
toro68 is offline
Old July 3rd, 2011, 06:59 PM
Tony
here it is I ran it years ago and it was a major step up from my 780 but it is only a single pumper so it has a flat spot but when it catches it turns on. It dont have choke plates at all. My motor buddy said he has a secondary tube kit for it Im going to try it on my 462 Im building just trying to figure which one it is because they made 2 models and thought you guys might like to see it, its a cool carb I have had it for 30 years
Old July 3rd, 2011, 07:26 PM
very cool
Old July 3rd, 2011, 07:33 PM
That's one helluva thing...
Old July 7th, 2011, 06:01 PM
Bill in NC's Avatar
That's got to be the coolest thing I've seen today! Thanks for sharing the pics.
Bill in NC is offline
Beau Dirt
December 27th, 2021 03:02 PM
jjokrm
November 19th, 2016 03:22 PM
63 F85 Cutlass
February 8th, 2015 03:20 PM
thapachuco
July 27th, 2013 02:51 PM
66ninetyeightls
March 28th, 2010 07:40 AM
Quick Reply: Holley 3 barrel
