Go Back   ClassicOldsmobile.com > Repair & Restoration > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-15-2007, 06:18 PM   #1 (permalink)
455nova
Junior Member
455 camshaft
what would be a good cam for a little more then mild 73 to 76 455,was thinking about using an rv cam,for the torc,would like some advise on what I might use.Thanks
455nova is offline   Reply With Quote
Old 05-16-2007, 04:43 AM   #2 (permalink)
Oldsguy
Oldsguy's Avatar
Some people do use cams with the "rv" grind. I have found that to be a moniker some companies use to describe their mild cams which still provide good vaccum. I think you might tell everyone a little more about the application and expected use, what kind of vehicle, etc. This might help some.
__________________
Dan
'46 2 door
Oldsguy is offline   Reply With Quote
Old 05-16-2007, 01:56 PM   #3 (permalink)
455nova
Junior Member
well the car is a 76 nova,as you might have known from my screen name,455 nova,looking for a cam for street and strip use,with a some what mild idle as long as have vacum,putting p/b in the car,next year will be doing somthing a bit wild with it,so it will be more strip then street,but this year I want to be able to drive it and drag it weekends..
Old 05-17-2007, 04:58 AM   #4 (permalink)
Oldsguy
Oldsguy's Avatar
Quote:
Does that mean you are going to re-build it with a different cam next year or will be using the same cam?
__________________
Dan
'46 2 door
Old 05-17-2007, 03:20 PM   #5 (permalink)
455nova
Junior Member
kinda what I am trying to do is build a low psi turbo set up,about 5 or so psi with a twin turbo set up I thought might be kool to try and see if it will work,but for right now,I am using a home built tunnel ram with 2 600 holley's
Old 05-22-2007, 02:00 PM   #6 (permalink)
regalrocket
Junior Member
A home built tunnel ram...I would like to see some pics of that.
__________________
-Olds 455 Powered 1981 Turbo Regal Sports Coupe
-Mistibushi Turbo 4 banger
regalrocket is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
