Go Back   ClassicOldsmobile.com > Repair & Restoration > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 02-15-2007, 05:12 PM   #1 (permalink)
cruznn
Junior Member
74, 455 engine
Hi
I just wanted to know how hard would it be to put this engine in a 71 cutlass? My car currently has a 350. with 350 trans. The engine is out of a 74, 88. Do I need to change moter mounts and trans? I know this is not the best engine for power, but it should be better than my 350. I am not looking to race it, just a little more power. I can get the engine for dirt cheap , complete.
Thanks,
Mike
cruznn is offline   Reply With Quote
Old 02-15-2007, 07:25 PM   #2 (permalink)
2blu442
Senior Member
Hi Mike
Easy swap. Trannie will bolt up fine, use the 455 flex plate and it will have holes for the both the TH350 and TH400 torque converters drilled in it. Engine mounts, the metal perch bolted to the crossmember needs to match the rubber mount. So if you don't change the metal perches then use 350 rubber motor mounts. Minor details would be exhaust might need tweaked as the engine is taller and wider. 350 manifolds will fit but not breath as well as big block manifolds. If your car is single exhaust the crossover pipe that runs under the oil pan will need to be changed. The pipe running from the manifold to the back of the car may need adjusted. The drive belt pullys may line up or you may have to bring over the power steering pump from the 455. Your fan shroud may or may not need tweaked. Depending on the size of your radiator you may need to upgrade it for hot summer days. I have made the swap in a couple cars and found I needed a 4 core to keep from overheating with stop and go traffic in the summer for my part of the country. Even with the smogger heads I think you'll enjoy the difference and you can always do other upgrades as the money comes along. Have Fun!
__________________
1964 Cutlass Factory 4spd
1965 442 4spd
1967 442 Auto
1967 Cutlass Convertible
1968 442 Auto
1969 442 W30 Auto
1970 442 4spd
1971 Cutlass Flat Top Wagon
1973 Che*vy 3/4 Ton 454/TH400 Tow Vehicle
Only the tow vehicle is finished!
2blu442 is offline   Reply With Quote
Old 02-15-2007, 08:13 PM   #3 (permalink)
cruznn
Junior Member
Quote:
Originally Posted by 2blu442 View Post
Hi Mike
Thanks for the great info. Its its bin a long time since I swapped a v8 in a car. I just did a swap in my ranger 2 years ago , but with the same size engine. I am currently going to replace body parts on it, because it was an Ohio car, (rusty doors , fenders) It only has 58.000 orig. miles , but you would not know it by the lower body panels. By the way, what day are you coming over to help, lol.
Mike
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
