Go Back   ClassicOldsmobile.com > Repair & Restoration > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 01-12-2007, 09:28 PM   #1 (permalink)
stew6371
Junior Member
questions from a newbie
im new to olds so bare with me. i want to build a bbo for my 84 cutlass. but i would like to make 500 hp with 8.5:1 comp and alum heads and a hyd roller cam. also i need to know who makes forged bottom ends for olds ad i plan on using a procharger also? thamks
stew6371 is offline   Reply With Quote
Old 01-13-2007, 12:15 AM   #2 (permalink)
texasred
Super Moderator
texasred's Avatar
To meet your specs will be a tough. 500hp pn pump gas? It'll take more expertise than your average engine guy.
May I suggest you contact
http://www.dickmillerracing.com/
http://www.fcrparts.com/Page_1.php
http://www.rocketracingperformance.com/
or any number of reputable Oldsmobile engine builders. Just stay the heck away from Mondellos.
C.J.
__________________
Home of the 1971 Cutlass Supreme convertible Super Karate Monkey Death Car.
texasred is offline   Reply With Quote
Old 01-13-2007, 04:13 AM   #3 (permalink)
stew6371
Junior Member
thats what im afraid of. i know i can achieve these goals with a sbc or a sbc, but i have never built an olds before and i wanted to stay all olds, but it may not be feesable to do so . thanks
Old 01-13-2007, 05:03 PM   #4 (permalink)
2blu442
Senior Member
If your serious about making an Oldsmobile go fast with an Oldsmbile engine it can be done. You might have to tweak on your requirements though. If you want to learn about Oldsmobile combinations go to realoldspower.com and view the Engine Builds\Combos and Hardcore Race\Engine Tech. Just don't say you want to put a Chevy in your Olds on that site.... you won't get any help or information from them if you speak "blasphemy" like that John
__________________
1964 Cutlass Factory 4spd
1965 442 4spd
1967 442 Auto
1967 Cutlass Convertible
1968 442 Auto
1969 442 W30 Auto
1970 442 4spd
1971 Cutlass Flat Top Wagon
1973 Che*vy 3/4 Ton 454/TH400 Tow Vehicle
Only the tow vehicle is finished!
2blu442 is offline   Reply With Quote
Old 01-13-2007, 06:24 PM   #5 (permalink)
texasred
Super Moderator
texasred's Avatar
IMHO-You don't really need a forged crank. There's plenty of drag cars running steel cranks.
Also IMHO-Aluminum heads? $1800 for unported bare heads which don't flow any better than cast heads out of the box. You spend a lot of bucks to save 50 lbs.
True-There's a guy on ROP (I forget his name...maybe RedDropTop?) runs a street 'charger on his Cutlass.
True-Ch#vy drivers makes a big deal out of 4 bolt mains, but their blocks have low nickel content unlike Olds....so 4 bolts in mush is better than two bolts in mush.
More true-I say it a lot, but my best bud runs a 70 442 W-30 with unported iron heads and a QJet deep into the 11s. He is also a builder/blueprinter specializing in Olds.
Really true-If you put a location in your profile, maybe we could suggest someone close to you.
C.J.
__________________
Old 01-14-2007, 04:27 AM   #6 (permalink)
stew6371
Junior Member
so edelbrock heads dont flow any better than c or #7 heads? or were u talking aftermarket steel heads? im not worried bout 4 bolt main. all my engines i built have been 2 bolt.im thinking of changing up a little bit and build a 350 olds for a little more rpm. is it possible to squeeze 450 - 500 hp out of a 8.5:1 sbo? thanks for help. i dont like the rop board. lot of jerks on that board.
Old 01-14-2007, 05:20 AM   #7 (permalink)
texasred
Super Moderator
texasred's Avatar
You can port 7 and 7a heads to flow as good if not better than 5 or 6 heads. A 350 is a fun little motor...I run one now.
As to 450-500hp, check out the links and talk to those pros.
C.J.
__________________
Old 03-01-2007, 05:43 PM   #8 (permalink)
stew6371
Junior Member
ok ive changed my plans. im going to go all motor. i going to build this car into a bracket car. im gutting the car as much as possible to get the weight down as much as possible. what do you all think of a 455 with 12-14:1 compression(on alky)with mildly ported or stock heads, a hyd cam, 500-550 lift approx, aluminum intake. will stock bottom end hold up to 5500 rpm ok?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
