ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Dealer Listings
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old January 2nd, 2005, 07:26 PM   #1 (permalink)
<66 Delta 88 Conv>
Guest
Posts: n/a
Post
I just purchased a 1966 Delta 88 Cinv witha 425. The engine runs, but has a knocking sound. I am not sure where it is coming from, though It does not sound good. I have read that it may be a spun bearing. Could someone tell me what else it may be? (trying to gage whether or not I need a complete rebuilt)
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old January 4th, 2005, 04:23 AM   #2 (permalink)
tedster
Junior Member
Post
Does the engine knock at idle as well as when you accelerate hard? If it knocks only when you accelerate, there is probably too much advance in the timing and/or you need to run a higher octane gas (this problem will get worse with "winter mix" gases that have additives that make the gas more volatile for easier starting in cold weather).
When I purchased my Cutlass, the 455 had a knock at idle which turned out to be a spun bearing. Hope this helps.
tedster is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1957 Olds super 88 4D Parts? Olds57rocketgal Eighty-Eight 7 May 30th, 2007 09:38 AM
crank casting 397363 needed neoinbiz Parts Wanted 3 December 25th, 2006 07:07 PM
68 Cutlass wont start 68oldsrocket Cutlass 24 December 19th, 2006 08:20 PM
another olds guy odin3eye Cutlass 4 March 30th, 2006 10:00 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
