| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
block ?
Is it hard to find a olds 400? Thanks
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
#3 (permalink) |
Yes....
The 1965 400 was used only in the 442. I know in 1968 they put them in Vista Cruisers too, I'm not sure what year they began to use them in other models than the 442. Also, the 1965-67 400 has a different bore and stroke than the 1968-69 400. They put the 425's in lots of different full sized cars from 1965-67, then from 1968 to 1975(?) Olds used the 455 in lots of different models. So the 425 and 455 are the most common big blocks to find. They will all fit in your 1965 F85 with some minor tweaks as the lower parts of the engines from 330-455 are all the same. Also the back where they bolt up to the transmission is all the same. Exhaust will be a little different, and you'll want to make sure you use the correct motor mounts for the mount perches in your car. Also using a matching set of pullys is very important. Do you have a 330 or 6 cylinder in your F85? John
__________________
1964 Cutlass Factory 4spd 1965 442 4spd 1967 442 Auto 1967 Cutlass Convertible 1967 Cutlass four door daily driver 1968 442 Auto 1969 442 W30 Auto 1970 442 4spd 1971 Cutlass Flat Top Wagon 1973 Che*vy 3/4 Ton 454/TH400 Tow Vehicle Only the tow vehicle is finished! |
#4 (permalink) | |
Super Moderator
Quote:
![]() There were actually three different Olds 400 block castings. 389298 B was used in 1965 442s only and is a short stroke 400 (4.00" bore, 3.98" stroke). 390925 E is also a short-stroke motor used in 66-67 442s and 67 Supremes (and Vistas?). 396026 G is a long-stroke 400 (3.87" bore, 4.25" stroke) and was used in the 68-69 442s and Vistas. All are externally identical, though the 67-earlier motors use a different crank flange bolt pattern and flywheel than the 68-up motors. 425s (65-67) and 455s (68-76) are also externally identical to the 400s. Any Olds big block bolts directly into the 65 F-85 using EXACTLY the same motor mounts and frame brackets as the 330. In 1965 (and in every year up to 1969) Olds used the SAME motor mounts and frame brackets for the BBO and SBO. Note that the BBO and SBO do NOT use the same "lower parts", however. The crank, rods, bearings, and even oil pan are different. The motor mount bolt holes ARE in the same place relative to the crank centerline, however. Use the 1965 400 motor exhaust manifold and the flanges will be in exactly the same place as the flanges on your 330 manifolds. The old pipes will bolt right up if you choose to use them.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#5 (permalink) |
Ahhh, now I see... thank you master (as we hear the flute music from the TV series "Kung Fu" play softly in the background)
__________________
#6 (permalink) |
Certified Fanatic
Actually the small block mounts are different than the big blocks- they are interchangeable but the big block mount has a built in interlock to prevent the motor jumping when the mount breaks-the '69-72 mounts have a more pronounced interlock...soo..use the big block mounts for your small block...'65-'68 big block mounts wil not interchange with '69-'72 mounts...the frame pads are different and thus the mounts are different...
__________________
![]() '57 S88 HC et al; '68 442 M20; '68 442 M21; '68 W30; '68 Vista et al; '80 -'84 Regency et al; '96,'98.'99 Aurora..Ignition ON ![]()
#7 (permalink) | |
Super Moderator
Quote:
ALL rubber motor mounts available today have the interlock feature. The early mounts have been redesigned to incorporate the interlock.
__________________
#8 (permalink) |
Thanks Joe! That was a lot of help. Now screw the 400 I'm on the hunt for a olds 455.
#9 (permalink) |
Super Moderator
You"ll find the 455 is easier to come by. Be sure to get the flywheel or flexplate with the motor, however. The one meaningful external difference between the 64-67 motors and the 68-90 motors is the bolt pattern on the crank flange.
__________________
#10 (permalink) |
Certified Fanatic
The original post read '400'...we must be using different books because mine for engine mounts has PN 404461 1964-67/all V-8 EXC 400 eng /sup 394198-401012; 401341 1965-68/ all v-8-w/ 400 engine; 404461 1968-73/ all 350 V-8; 406436 1969-72/ all400, 455 V-8...my book is # 743A...It's a battle of the books
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Mystery block | kevdog442 | Small Blocks | 4 | February 15th, 2009 08:30 AM |
| Has anybody used a 350 DX block? | Redog | Small Blocks | 72 | August 14th, 2008 08:38 PM |
| Big Block vs. Small Block Olds?? | bocoogto | General Discussion | 26 | March 18th, 2008 05:56 PM |
| New Kid in the block. | mont1le | General Discussion | 3 | February 12th, 2008 05:41 PM |
| Block off plate? | Redog | Small Blocks | 13 | December 14th, 2007 02:17 PM |
