ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Big Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old May 17th, 2009, 11:40 AM   #1 (permalink)
ctrain22
ctrain22's Avatar
which heads??
I just picked two 455 motors to put in my 68 442 project. They both need rebiuild, but curious about the heads, and which set to use. One set is "G" cating and the other is "K". Whicg head is better. Plan on mild street build for daily driver, nothing more than a mild cam and headers.
__________________
68 442 Convertible
ctrain22 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old May 17th, 2009, 01:57 PM   #2 (permalink)
442Harv
Their both good heads. G,s are 71, so have harden seats. K,s are W30 replacement heads, and use on a lot of boats. K ,s may have the larger valves? If they need new valves you can put in larger valves.,in either.I would probaby use the K. But if you want to sell a set, you could go with the G,s as the K,s may be easier to sell, and bring a little more money.
442Harv is offline   Reply With Quote
Old May 17th, 2009, 07:18 PM   #3 (permalink)
joe_padavano
Super Moderator
Quote:
Originally Posted by 442Harv View Post
...K,s are W30 replacement heads...
Well, not quite. By the mid-1970s, the only heads in the Olds parts system were J and K castings. K heads superceded all the performance head applications, J heads superceded all other applications. Saying that K heads are W-30 replacement heads is like saying that J heads were replacements for C heads. They were the best available at the time, not necessarily exact replacements.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old May 17th, 2009, 07:45 PM   #4 (permalink)
2blu442
2blu442's Avatar
The Ka will have 2.07 intake valves. The G may have either the 2.00 or 2.07 intakes. But you can cut out the small valve head seats and have the larger ones installed as Harv said. Depends on what your plans are for head work. I'd be comfortable with either one, but believe the larger intake valves would breath a little better. John
__________________
1964 Cutlass Factory 4spd
1965 442 4spd
1967 442 Auto
1967 Cutlass Convertible
1967 Cutlass four door daily driver
1968 442 Auto
1969 442 W30 Auto
1970 442 4spd
1971 Cutlass Flat Top Wagon
1973 Che*vy 3/4 Ton 454/TH400 Tow Vehicle
Only the tow vehicle is finished!
2blu442 is offline   Reply With Quote
Old May 20th, 2009, 05:56 PM   #5 (permalink)
ctrain22
ctrain22's Avatar
Is there really a difference between the G & GA or K & KA heads? These are GA and KA.
__________________
68 442 Convertible
Old May 20th, 2009, 06:15 PM   #6 (permalink)
chris83
i would go with the g heads but if you can find a set of big valve c heads you will have more power than you can handle make sure they are the big valve and not the small valve heads you wont be disappointed
chris83 is offline   Reply With Quote
Old May 21st, 2009, 04:26 PM   #7 (permalink)
Warhead
Purchase a brand spankin new set of big valves, and have your machinist correctly install them in whatever set you think will look better on the car. They will flow almost exactly the same as the other, and be within 2% of the C heads (no porting).
Get 2.125 intakes, 1.625 exhausts for max power.
See my response on ROP concerning spring seat depths.
JMGDO
Jim
Warhead is offline   Reply With Quote
Old May 24th, 2009, 05:17 PM   #8 (permalink)
ctrain22
ctrain22's Avatar
I am leaning towards using the KA heads, but I think I read somehwere about the exhaust crossover needs to be blocked? Can someone enlighten me on this issue. Boy, this is not like chevy where you only had to deal with round or rectangle heads. Do the GA heads have the same characteristic? If the GA heads have the big valves (which I suspect they do), would they be a better bet. This is not going to be a drag car, just good street performance driver.
__________________
68 442 Convertible
Old May 24th, 2009, 07:24 PM   #9 (permalink)
joe_padavano
Super Moderator
Quote:
No more so than on any other Olds head. If you are not planning on an ultimate performance race car, don't worry about the crossover.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
Old May 25th, 2009, 08:43 AM   #10 (permalink)
Warhead
MUCH easier than the BB Chevy.
You forgot to mention closed/semi/open chamber BBC heads.
Other than valve sizes, and spring seat depths, these heads are pretty much identical. Measure the valves to be sure.
Pull out the set that will be the easiest to lift (it just does not matter), and take them to the machine shop for a standard rebuild. You will be happy with the performance, because they will be going on a 455. You don't have to do anything else.
Old May 26th, 2009, 07:02 PM   #11 (permalink)
64Rocket
64Rocket's Avatar
Just as has been said, for a daily driver any of the heads will do. The valve size will not make any difference. For a cruzier, troling the streets, long drives in the evening, after you close the hood no body can tell the difference.
Flip the coin and pick which ever.
Gene
__________________
64Rocket is offline   Reply With Quote
Old May 27th, 2009, 11:49 AM   #12 (permalink)
csouth
Send a message via Yahoo to csouth
Not trying to hijack the thread, but since you guys were on BB I thought I'd ask. I know a guy selling a 455 with J heads for @ $400. I did hear that these were restrictive and should be avoided. I know its a newb quest, but are engines these even worth buying?
__________________
Chris
Takin' Baby steps....
'72 Cutlass S
csouth is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
#5 heads glassjaw442 Small Blocks 8 April 20th, 2009 01:45 AM
#5 HEADS ZASX Parts For Sale 1 April 17th, 2009 04:39 PM
Ga or E heads? import extermination Big Blocks 9 April 8th, 2009 02:53 PM
g heads 71442masonb Big Blocks 5 October 29th, 2008 02:47 PM
Heads gdjackson Cutlass 6 October 5th, 2007 09:29 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
