Reputable engine builder/ installer in MS
I have a 1972 cutlass supreme with a olds 350 engine and th350 transmission. The car is a head turner but I have wanted to swap the olds 350 out for a olds 455. A couple of shops said that I need to go with a chevy 454 due to the availability of parts. Do anyone know of a good engine shop near Biloxi, MS that can do the engine swap?
You need to do research. Whenever I have a project I try to plan out everything. Do you have a engine yet? Sounds like you're looking for a shop to take/drive your car to, then pickup when done.
Yes I would like to find maybe a 455 crate engine, have it shipped directly to the shop if the shop can not order me one then just drop off the car and pick it up when done. I have found a couple of shops online that have 455 crate engines in stock for around $10k, that does seem a little pricey but I guess you get what you pay for just not trying to get ripped off too bad lol.
And a billet crank will run you 2K alone. With that you'll have over 3K just in the rotating assembly. From there you can skimp if you want but that doesn't make sense if you're spending that much on a crank alone.
Gearhead442
January 21st, 2012 04:52 PM
Gearhead442
January 20th, 2012 05:24 PM
