Throttle Shaft Bushings
Its been some years for me.
I purchased a kit from summit under the JET brand. The kit contained some bushings and a reamer. Enough to do several carbs.
The hard part for me was removing the throttle blades from the shaft. Those little screws are staked in and can break. I believe I ground the end of the screw off before removing. I sourced the small screws somewhere? after breaking a couple of them.
I bought my kit from www.quadrajetparts.com. Very easy kit to use.
I have a kit with the drill, some extra bushings and such if you want.
I replaced them on one of my carbs.
Not a bad job to do, as long as that is the only thing wrong with the carb. My carb turned out also to have issues with crap stuck in the little passages.
Oldssupreme
August 19th, 2016 09:36 AM
rothlane'68
November 29th, 2015 06:54 PM
dancutlass
August 21st, 2012 06:26 PM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
