| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
455 rocket
Hopefully you guys can help me out.Im normally working on Chevys but I just picked up an engine that was pulled out of a 1970 Olds.I was told it was a 455 rocket,I have no idea what it is for sure.Please tell me what to look for to find out what I have.What is the difference between a 455 and a 455 rocket?This engine and trans has about 120,000 miles on them,I give $200 for the pair and it runs good.Did I get hurt any on what I give?Any help will be appreciated.
Thanks |
#2 (permalink) |
Rocket is a nickname for almost any modern OHV V8 engine Oldsmobile made since 1949. Sometimes the marketing was obvious, sometimes not. Your engine is a Rocket whether it is a 455, a 350. If you are sure about the year then it is either a 350 or 455. The esiest way for me is to look at the head on the driver's side. On the lower left corner, sort of below the alternator and above the power steering you will see a Capital letter cast into the head. You may have to clean it with a rag or some spray carb cleaner or engine cleaner to remove the grease and oil if the engine is dirty. If it is a capital letter then it is a 455, look for a C, D, or maybe F. If it is a number or a number with a letter suffix then it is a 350. Look for a 6, 6A, 6a, or 7 (I think). Other ways, the big block is 13 inches wide at the front water crossover on the intake, a small block is 11 inches. Finally, the sure fire way to know all about the engine is the engine code cast into the block below the water neck, above the water pump on the horizontal surface of the block where the oil pressure sender is. Record that number and someone here can decode it for you.
__________________
Dan '46 2 door |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1978 intake manifold | jjatich | Small Blocks | 4 | 07-29-2007 07:57 PM |
| Production figure? | Michael C. Nazaruk | Other | 0 | 09-09-2006 06:54 PM |
| super 88 interior | george88 | Interior/Upholstery | 3 | 09-04-2006 12:04 PM |
| 55 Olds Hydramatic transmission - Newbie | Pookster6 | Transmission | 4 | 09-02-2006 06:21 PM |
| Newbie needs your help! | DinkyDow | Cutlass | 1 | 09-01-2006 05:02 AM |
