'68 Ram Rod questions
Can anyone confirm what the correct sticker should be for the air cleaner lid on a '68 Ram Rod? Mine says Rocket 350 and thinking it should be the Ram Rod sticker but I have only seen those on '69's even though '68 was the year referred to as "Ram Rod". Also, what should the correct 4spd gear shifter ball look like? Mine is white and not sure if that is right. Thanks!
My 69 Cutlass 'S' Sports Coupe W-31 4 speed has a black shifter handle **** (which I am very confident is original) I can't confirm 1968's...... PS: Some day I want to get our cars together for a photo opp, yours is one of 5 and mine is one of 7 imported to Canada!!! 2018 sound good?
Hi Sean hope you're enjoying the car. That is the correct pie pan on your car. Also **** should be black I just put the white one on. Thought it looked better in that interior.
Bernhard
April 27th, 2013 10:54 PM
