Leaking oil pan
Old May 13th, 2015, 11:58 AM
442craig's Avatar
Leaking oil pan
So I have a oil leak in the back of my '68 442 400. The engine is brand new. How difficult is it to remove the pan? Will it slide out or do I need to lift the engine? Also what type of gasket should I use.
Thanks in advance
Craig
442craig is offline
Old May 13th, 2015, 12:08 PM
It's a pita to do it with the engine in the car. I would get under there and check the pan bolts and snug them down a little bit all the way around the pan. Also double check the valve covers for leaks.
oldcutlass is offline
Old May 13th, 2015, 12:12 PM
442craig's Avatar
Yep, I have done all that, this is where I'm at. Not the news I was looking for!
Craig
442craig is offline
Redog
October 20th, 2015 03:29 PM
defiant1
August 12th, 2014 04:43 PM
defiant1
August 26th, 2011 09:45 AM
Dan Wirth
October 18th, 2009 07:27 PM
Quick Reply: Leaking oil pan
