Recommended engine oil for 455 Rocket
How many miles on it? Fresh rebuild? If fresh what was the bearing clearences set to and what type of oil pump? What climate do you drive it in? Whats your current idle and at speed oil pressure?
Generally 10W30 is good all the way up to 20W50. Thinner is better in colder weather. Opposite for Dessert weather. You'll get plenty of opinions here. Its a personal choice. So that's why I provided a range. Use a high quality oil made for flat tappet cams...if thats what your running. Several vendors cater to this crowd. You need high ZDDP content with flat tappet cams.
I use 15W40 Rotella "T"or Shaeffers 15W40. I also run with a can of Prolong.
Truth. ^^^
I'd venture to say that zinc content is even more important than specific weight. Specialty suppliers like Edelbrock make high ZDDP formulae intended for use in old cars but they're pricey. Lucas also makes a high-Zinc variant which I've been using in my 400G for awhile with no problems.
As to weight, you'll likely be fine with 10W-30 or 10W-40 under most conditions.
I do mine every fall before I put it away for the winter.
I just read that back and it sounds funny. I meant the car.
Last edited by BangScreech4-4-2; July 10th, 2015 at 01:28 AM. Reason: Clarification.
Indy_68_S
Drivetrain/Differentials
March 5th, 2012 06:04 AM
labrats804
July 19th, 2007 07:16 AM
