1970 442 production
Old August 30th, 2014, 08:17 PM
mdh157's Avatar
1970 442 production
Does anyone know if there is a production breakdown of 1970 442 by transmission attachment (4 wide,4 close,3 spd stick, floor AT and column AT)?
mdh157 is offline
Old September 2nd, 2014, 04:41 PM
BlackGold's Avatar
I have numbers through June of 1970, so almost the entire production year. Out of a total of 18,938 442s built by then:
416 (2.2%) had the M14 3-speed manual floor shift.
4972 (26.3%) had the M21 4-speed manual close ratio floor shift.
13552 (71.6%) had the M40 automatic.
For what it's worth,
10637 (56.2%) had the D55 front console.
The 3-speed manual column shift and M20 4-speed manual wide ratio were not available on the 442 model.
There is no breakdown between column-shift and floor-shift automatics. But you can be sure that the vast majority were floor-shift (for the 442 model).
BlackGold is offline
Old September 24th, 2018, 09:07 AM
1of1442's Avatar
Blast from the past
I’m a little late to the party but , I love it when I stumble across these little nuggets of information that are typically non existent! Is this info potentially useful to break down transmission by body style? I’m specifically interested in the sport coupe with the M40 and no D55 front console. I have seen the figure by trans only at about 1040 if I recall correctly?
Last edited by 1of1442; September 24th, 2018 at 09:08 AM. Reason: grammer and spelling
1of1442 is offline
oldsmobilejuggernaut
October 10th, 2017 09:27 AM
Dru707
July 22nd, 2015 03:07 PM
rbbewright
January 28th, 2014 06:05 PM
442dale
February 7th, 2013 07:03 PM
Rusty Boltz
March 28th, 2012 03:14 AM
Quick Reply: 1970 442 production
