Newbie looking at a 68 Olds 442
Old June 27th, 2014, 12:07 PM
  #41
allyolds68's Avatar
Originally Posted by Canadian Greg
Then the factory installed the wrong covers on my 68?
Unlikely.
Let's see a pic of yours. I suppose it's remotely possible if you have an Oshawa built car it might have something different however I've never seen a stock valve cover with a breather in the end
In 68 there was only one configuration for 442 big block valve covers. All 68's 442 got notched valve covers (though not shown in this picture). The vents were located in the center of the valve covers.
allyolds68 is offline
Old June 27th, 2014, 12:31 PM
  #42
starfire's Avatar
Getting that A/C system back will probably run you another $1k
Just getting an A/C dash recovered at Just Dashes will set you back $1k.
starfire is offline
Old June 27th, 2014, 01:20 PM
  #43
BackInTheGame's Avatar
"VIN Check"
"Well everyone... I guess newbie is very thankful to you all. After hearing all the info, I found a site to do a vin check and it actually came back with history of the car. The car is listed as salvage records and cause of loss was collision on 11/27/85. On to continuing my search. Greatly appreciate everyone's help."
I don't mean to hijack the thread - just curious: How/where did you check the VIN and receive back a history? I've been digging around for just this type of info and come up blank at every turn - "VIN Incorrect" or "No Records Found" or "VIN too old..." etc.
I'm restoring a '68 "numbers matching" unit, and block and trans do indeed have "matching numbers"... but there are some things that don't seem quite right about my project .
TIA
Rich
BackInTheGame is offline
usertroy
December 13th, 2012 08:19 PM
Scottem
May 29th, 2012 11:24 AM
marty
Site Help
November 30th, 2009 06:08 PM
bobem12
June 18th, 2007 03:17 AM
Jeffemac
June 1st, 2007 11:37 AM
Quick Reply: Newbie looking at a 68 Olds 442
