trunk paint
If someone else doesn't answer this for you sooner, I'll get some pictures from my 1967 Fremont built Cutlass Supreme 4 door. Its a grandma car that I purchase with low miles. I believe, but don't want to count on my memory, that the trunk had spatter paint. I know that it had a rubber mat on the floor and a cardboard cover for the spare tire. They were both the same print.
One of the 1967 guru's can clarify or correct me, but I'm thinking the 442 would have the same trunk paint as the Cutlass Supreme in 1967. I'm not sure if there would be any difference between assembly plants.
John
John
My '67 442 is a Lansing car and the trunk floor is black and aqua spatter paint and it has a hounds tooth black and aqua floor cover. Plasticoat paint as I remember. Got it at the local car parts place. Two cans and I cleared it with satin for more durability. Some cars also had an optional black rubber mat. There are two different floor covers available the cheaper one does not lay as well as the pricier one though they look very much the same.
jensenracing77
Paint
September 10th, 2014 02:33 PM
JpMotorsports
May 15th, 2014 07:08 AM
