1965 442 rear seat belts
Old March 18th, 2014, 10:16 AM
DaveD65's Avatar
I want to install rear seat belts in my 65. I saw in an old post that there may be pre-drilled holes or flat spots to locate drilling my own holes. I don't have either in my car. Can someone post pictures of where the seat belts should be attached? I'm ordering the attachment bolts / support plates and can drill my own holes, I just need to have idea where that should be. Thanks
DaveD65 is offline
Old March 18th, 2014, 11:01 AM
DaveD65's Avatar
Sorry about the location of this post, I'll get my next one in the right forum.
DaveD65 is offline
Old March 18th, 2014, 11:52 AM
TK-65's Avatar
TK-65 is offline
Old March 18th, 2014, 12:22 PM
2blu442's Avatar
Jason, could they have done different things between the different assembly plants? Attached are photos of a floorboard portion cut from a 1965 Post car. It has two oval impressions on the outboard positions, but I don't see anything for the two inboard positions. This car had loops added in the center but they don't have anything to do with factory seat belt anchors. John
2blu442 is offline
Old March 18th, 2014, 12:23 PM
2blu442's Avatar
Dave, I moved this to the 442 forum for you.
2blu442 is offline
Old March 18th, 2014, 01:05 PM
Justin
oldstata's Avatar
John mine looked like yours when I installed mine they has a little dimple where I drilled turned out great
oldstata is offline
Old March 18th, 2014, 01:10 PM
Justin
oldstata's Avatar
oldstata is offline
Old March 18th, 2014, 06:23 PM
TK-65's Avatar
My car is a Fremont car. Id have to look at my other car to see what it looks like. I never noticed the difference before.
TK-65 is offline
Old March 18th, 2014, 06:42 PM
DaveD65's Avatar
Mine is a hardtop assembled at the Fremont, CA. plant. I just looked again and don't see the dimples. These pictures give me a good idea of the location I need to drill the anchor holes. Thanks for your help.
DaveD65 is offline
Old April 23rd, 2014, 05:23 PM
DaveD65's Avatar
John, the picture of the measurement from the bracket guided me to find a dimple.
My car doesn't have the flat spots with the dimples to locate the holes but once I knew where to look, the dimples were there. I drilled the holes, used the oval backing plates and installed the seat belts. Thanks to all for your replies.
DaveD65 is offline
Old June 23rd, 2014, 07:39 AM
HiCompOlds's Avatar
DaveD65...I want to add rear seat belts to my '65 Cutlass as well and now is an opportune time for me as I'm doing some interior work. Where did you by the rear seat belts and hardware? I need blue belts. Thanks.
HiCompOlds is offline
Old June 23rd, 2014, 06:22 PM
Justin
oldstata's Avatar
I pulled mine from a late 70s oldsmobile from a pull in save
But here is a link will need to cut and paste
http://www.profitautointeriors.com/productSearch.aspx?ukey_make=266&ukey_model=14289& modelYear=1965&ukey_category=30384
oldstata is offline
Old June 23rd, 2014, 06:44 PM
HiCompOlds's Avatar
Question
http://www.profitautointeriors.com/p...category=30384
Thanks but the seat belts on that site are listed for the front.
Old June 23rd, 2014, 08:42 PM
DaveD65's Avatar
I got the seatbelts at SEATBELTSPLUS.COM. I went with the basic 60" black latch lift style. They're in and function fine.
DaveD65 is offline
jcmoretti
July 11th, 2018 03:07 PM
69442murph
January 19th, 2013 11:55 AM
sx455raidercelticfan
December 26th, 2010 04:13 PM
December 21st, 2010 08:59 PM
2blu442
November 23rd, 2009 01:18 AM
Quick Reply: 1965 442 rear seat belts
