| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
? about Chassis Coding?
Does any body know what code these are in the attached image? They are on the back driver trunk area
on the chassis. Someone once told me that they marked options and such on chassis after the car was done with production? is this true?
__________________
Owner of BigBertha442 Sal |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
feed the pig
I recoginize the "3667" as being a convertable. To confirm, the frame would be boxed in the appropriate areas.
I can't help with the rest. By the way, nice job on the photo, it clearly shows the numbers. I believe there is another series of numbers near the cowl/door area that should be vin related. Do the numbers in the photo area relate to your vin at all? These are the only two areas I am familiar with that have stampings. I don't know they have any thing to do with options though.
__________________
1971 Cutlass S Holiday coupe-455/th400 3.23 Oldsmobile they were meant to be driven. Last edited by don71; March 1st, 2008 at 09:54 PM.. Reason: nice photo |
#3 (permalink) |
Yes I also noticed that # 3667 but it is not boxed in it is a 1972 442 - S Hard Top. I will look for the other numbers today.
__________________
#4 (permalink) |
I have just discovered after trying to figure out what one of my frames are that the first #, 7 digits is the part number. I have an old mitchell interchange manual and found my frame to be a 3960733 which is a 68 or 70 F-85. The 2 letter code will tell you the factory code for what it goes under but you will find this only in an assembly manual. I have not figured out the rest yet but will keep you all informed. I will look and see if I can find your # in my manual.
#5 (permalink) |
Yours is a 72 frame for cutlass/f-85. If you have a assembly manual, go to the frame ID page and there should be a box with the letter codes. The 3 #'s after the part # possibly could be a julian date but not sure on the rest. Julian date is out, Mine is 401. ???? Yours is 366, Not it either unless it was a leap year. ????
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| CONVERTIBLE CHASSIS WANTED | real442 | Parts Wanted | 3 | February 3rd, 2008 12:48 PM |
| Chassis Question | real442 | General Discussion | 1 | January 27th, 2008 01:30 PM |
| Body/Chassis Chalk Markings | desert442 | Chassis/Body/Frame | 2 | January 19th, 2008 10:08 PM |
| Who supplies the best body and chassis mounts? | The Pope | Chassis/Body/Frame | 0 | July 11th, 2007 06:13 AM |
