| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Member
G-Head Decoding
Hey guys,
Most of the decoding info I've used comes from 442.com. For decoding heads, it's described as G heads being from '71 and Ga heads being from '72. So, I understand the difference between the two, but the site was vague as to how Ga would actually appear on the head. Is it literally an upper-case 'G' followed by a lower-case 'a', or is it the 'G' in the usual place and size, and an upper-case 'A' half the size, about an inch and a half to the right of the 'G'? There's a pretty significant HP and torque difference between the two, so of course I'm curious... |
| Sponsored Links |
#2 (permalink) |
Senior Member
Heads
It's the normal sized G with a capitol A less than half the size to the right down low. I believe the heads alone are the same between the two as far as performance, but that the compression may have dropped. Also that may be the year that they began measuring the horsepower from the rear wheels rather than the rear of the crankshaft which made a big difference in numbers, but actual on the street the change isn't that dramatic.
__________________
1964 Cutlass Factory 4spd 1965 442 4spd 1967 442 Auto 1967 Cutlass Convertible 1968 442 Auto 1969 442 W30 Auto 1970 442 4spd 1971 Cutlass Flat Top Wagon 1973 Che*vy 3/4 Ton 454/TH400 Tow Vehicle Only the tow vehicle is finished! |
#3 (permalink) | |||
Junior Member
My source says the chambers are the same size. Compression difference would be in the pistons.
Quote:
The Feds set standards for dyno testing by the manufacturers. Under the new regulations, all accessories/belts had to be on the engine during the pulls. Prior to that time, accessories were not necessarily used. Quote:
Most of it, was an accurate measurement of the the actual power loss caused by the higher gears, lower compression, leaner mixtures, and earlier ignition, needed to meet EPA regulations. Quote:
A "conspiracy theorist" could conclude that the Government mandated those regulations, in order to lessen the impact of the lower HP numbers. Norm |
#4 (permalink) | |
Member
Quote:
Terry
__________________
'72 Supreme 455/M20 (1 of 77) '70 SX 455 Conv. '72 442 (455 OAI) '74 Vette L82 4spd. '96 Vette LT4/6spd CE coupe '72 Chevy Custom Dlx LWB pickup highoctaneauto.com ('72 V Code Registry) sx455.com sevencolorsky.com |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Decoding VIN number on a 64 F85 | jrblanke | Cutlass | 7 | 12-25-2007 02:49 PM |
| 69 F85 manual shift vin decoding | coldone1 | Other | 4 | 03-20-2007 10:38 PM |
| need help decoding VIN and Cowl tag for my 66 Toro | DesertToro | Toronado | 1 | 01-16-2007 08:10 PM |
| HELP!! Decoding my 1964 Oldsmobile | 1964OldsmobileF-85V84Door | Other | 2 | 12-15-2006 05:53 PM |
| need help decoding 442 | new 2 me | 442 | 2 | 11-17-2006 06:23 AM |
