ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Vehicle Lineup > Cutlass, 442, and Hurst/Olds > 442
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old October 25th, 2009, 08:16 PM   #1 (permalink)
fjross
71 Ignition switch
Would anybody know if there is any adjustment with the bolts that attach the ingnition switch to the column. I notice that I can still turn on the accessory when the key is out.
Thanks Dave
__________________
1965 Factory Five Cobra replica
1971 442 convertible
1977 Toyota FJ 40
fjross is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old October 25th, 2009, 08:31 PM   #2 (permalink)
70 cutlass s
Sounds like the lock cylinder has wear. If ignition switch starts the car fine, and when turned off nothing is on, and key is at the locked postion and you can pull the key out. The ignition switch is fine and doesn't need adjustment, but you can turn the lock cylinder with out the key. Than it is the lock cylinder.
70 cutlass s is offline   Reply With Quote
Old October 26th, 2009, 04:45 AM   #3 (permalink)
fjross
Thanks for the reply, I just got done installing a new lock set in the entire car. Yesteday was the fisrt time that I had power on the harness since the restoration and had a few other larger problems (BLOWER MOTOR NOT WORKING) to trace out than the key issue. I finally figured out that the new high speed relay was defective. I was hoping that this issue was just an adjustment to the ignition switch.
Dave
__________________
1977 Toyota FJ 40
Old October 26th, 2009, 05:24 AM   #4 (permalink)
70 cutlass s
I would say the lock cylinder is ok since it is new. Sounds like something else is wrong. Does your steering wheel lock after you take the key out. It might not put together right.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ignition Switch Removal grt05 Interior/Upholstery 4 April 29th, 2009 05:36 AM
Sloppy ignition switch dingusboy Cutlass 0 April 14th, 2009 06:58 AM
ignition starter switch 64oldsd88 General Questions 4 March 30th, 2009 01:16 AM
How 2 change ignition switch Benny Blanco Cutlass 2 May 25th, 2008 05:17 PM
ignition switch oldbutgood Electrical 1 November 12th, 2002 11:00 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
