| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Heater hose routing/look
This should be an easy one. I'm hoping one of you guys w/ a 68 442 has a picture of the routing and clips/if any of the heater hoses. I know one is molded and the other, pretty much a straight shot to water pump. I'm replacing the generics that a previous owner had and want to do it correct, clamps and all. I thumbed through my Year One catalog and others but could not find a shot without the air cleaner.
Thanks in advance!
__________________
'68 442 Sport Coupe,455 4 speed(M20)& Bench 3:42 Posi. Force Air Induction Added. |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Factory AC car or not? I assume not.
__________________
Patton Glade 70Post Restorations Austin, TX GM A-Body Gas Tank Pads/Insulators---click on link http://classicoldsmobile.com/forums/...tion-item.html |
#3 (permalink) |
No AC
__________________
#4 (permalink) |
Cruisin' the Vistas
#5 (permalink) |
The 3rd and 6th pic in the pics Bluevista linked to should work for you. NOTE the placement of the long heater hose and where it rests on the Non-AC passenger side alternator bracket. That's also where the short black foam insulating sleeve is placed.
__________________
#6 (permalink) |
Thanks guys, helpful.
I noticed there seems to be a mix between whether "hightower" clamps are used versuses tension clamps? My take is tension clamps were used on the heater hoses from firewall, but hightower used on the bypass tube.
__________________
#7 (permalink) | |
Quote:
Correct on the tension clamps for the heater hoses. The bypass and radiator hoses on a 68 use the double wire clamps not the post type aka hightower clamps
__________________
http://motorhead43026.tripod.com/two...vorite_things/ 68 442, original engine and 4-speed transmission (Nasty) 69 Cougar 33,000 original miles (Nice) 2003 Honda Accord boring,anemic,dependable (Ho Hum) "No matter how fast I go, I still can't pass that gas station." "If you are an engineer by trade all things are not black or white, live a little and step into the gray area" |
#8 (permalink) |
Here's a couple for you. Mine is a Sports coupe with no AC.
I don't have any clips. And those are the original hose's ![]() ![]()
__________________
![]() Follow link to Pictures and Video... RATE MY CAR http://www.cardomain.com/ride/3068977 |
#9 (permalink) |
Thanks for the pixs. I plan to tackle this weekend, have been waiting on the back ordered "molded" hose but it arrived today. I'll post the completed set up to finish out the thread for future use.
__________________
#10 (permalink) |
Well here it is completed. Used the YearOne clamp set and also the insulator sleeve over the Alt bracket. Hopefully, it's useful to others down the road. Thanks for comments on this thread.
__________________
'68 442 Sport Coupe,455 4 speed(M20)& Bench 3:42 Posi. Force Air Induction Added. Last edited by 4speedBench; October 4th, 2009 at 06:55 PM.. |
#11 (permalink) | |
Quote:
Looks good, just one tip once the engine goes through a couple heat cycles go back and re-tighten the wire clamps.
__________________
#12 (permalink) |
Certified Fanatic
The heater hose blew off my wife's car when I used one new wire tension clamp
so I put two on tight together and Jane's your aunt ![]()
__________________
![]() '57 S88 HC et al; '68 442 M20; '68 442 M21; '68 W30; '68 Vista et al; '80 -'84 Regency et al; '96,'98.'99 Aurora..Ignition ON ![]()
#13 (permalink) |
Nillson, Yellowstatue,
Agree. I have re-filled with water for test run, but weather has not been cooperating so I have not had a chance to check for leaks. Got to admit, the tension clamps on the heater hoses have me worried. YearOne sends the same size clamp for both the 5/8's and 3/4 size hoses??? I'm not too confident that I won't have to improvise....
__________________
#14 (permalink) |
Does anyone make this style clamp? This is what I have on mine and should be the original type.
__________________
#15 (permalink) |
Dan, I think Fusick has them. Pretty sure that's where I got mine.
__________________
1968 Olds 442 Sports Coupe 4-speed/bench seat |
#16 (permalink) |
Tom,
I looked in there catalog and didn't see it. I don't need them right now but would like to get them before you can't find them any more.
__________________
#17 (permalink) | |
Quote:
No chance of these becoming extinct.
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| '61 98 fuel line routing? | dantana | Chassis/Body/Frame | 2 | August 21st, 2009 11:58 AM |
| How to connect heater hose? 67 400 | Flye | Big Blocks | 6 | June 25th, 2009 03:34 AM |
| Transmission Cooler Routing | #1CutlassSupreme | Transmission | 9 | June 14th, 2009 09:45 AM |
| Heater hose / where too? | tim72 | General Discussion | 2 | May 15th, 2009 10:09 AM |
| Heater hose routing | Colorado Olds | Other | 2 | March 2nd, 2008 02:57 PM |
