1964 - Differences between an F85, 4 Barrel, 4 Speed, Dual exhaust car and a 442?
The primary engine difference was the cam. The 310 HP version of the 330 in the 1964 442 got a 278/282 degree cam with 0.432" lift. Lesser 330s got the 250/264 deg cam with 0.389" lift. Of course the 442 also got the dual snorkel air cleaner and the rear anti-sway bar, but the cam was the reason for the difference in HP.
The crankshaft bearings also are made of a different material. The 442 bearings are made of moraine M-400 rather than M-100 and this will be stamped on the bearing. If you take the engine apart, be on the look out for these differences.
Well, for what it's worth, the 1965 SPECS booklet doesn't show an FE2 or other suspension option for lesser Cutlii either.
thanks
So, looking at the 1964 options and accessories, the L74 290HP option could be ordered on a standard F-85, but the option itself was called a 290-HP Cutlass V8. So can a standard F-85 have this optional 290HP engine without being a Cutlass?
Correct, but the OP asked about a "four barrel, four speed, dual exhaust" F85 as compared to a 442. The only way to get an F85 configured that way was by ordering RPO L74 and RPO M20.
Joe, I'm not answering that way. My interpretation was "can" a 3000series car have the 290 hp engine without being a cutlass? Yes. Of course, if it was answered in your reference to first post, then it would need the options as you stated to be closer to a 442 look, but still wouldn't be a cutlass.
I answered his question from post #7. Which does not ask about difference b/w f85 442 vs cutlass 442. It's a question about a 290hp engine which was NOT in the 442. Hence the way I answered as a non-442 question. Make sense?
The reality is, you should ask the OP what his question was.
He's asking if the f85 could have a 290hp engine and not be called a cutlass. If so, this helps him understand that an f85 could be cloned easily if already equipped with a 330, M20 and duals....just add a sway bar, emblems and dual snorkel. Available from dealership back then.
Great discussion guys! I had to go show some houses so I couldnt check back in until now.
In an effort to exhuast hypotheticals, I wondered if a base club coupe - like mine, could in theory be equipped to appear as a 442 using a series of checked boxes on an order form because, it seems you could order that 290HP engine, get a 4 speed, and have dual exhaust at the beginning of the model year without ordering a 442 - and that engine is visually the same, right?
In addition, other posts I have read say that the heavy duty frame is the same for all manual equipped cars.
So basically, what I am getting is the 442 package had internal engine components that are hard to verify, higher spring rates that are hard to verify, the dual snorkel air cleaner, three emblems, boxed control arms, rear sway bar, and trunk lid access holes.
I also read that if equipped, the manual steering box should have a 20:1 ratio. How do I check that?
Is the driveshaft bigger? Is the front sway bar bigger?
Just me being uptight...trying to cross ts.
Thanks for the input!
In 65 the front bar and driveshaft are bigger on a 442. Not sure if that helps you.
Thanks for the comment. I have since found out that the front sway bar in a 64 442 is bigger - and my car measures out - but I think they got even bigger in 65
not sure about the driveshaft still...
66Dynamic
April 17th, 2014 04:52 PM
64 Cutlass
January 22nd, 2010 06:59 AM
